So are you sure there are ZERO screws needed to install this body kit, even on the Side Skirts which have obvious mounting holes?
Also I'm not sure if screws are your body works only enemy as once those Skirts are glued to the originals I'm sure you can't decide to remove them without damaging the original skirts which will then have to be replaced?
I'll admit it, you got me.
I took a really close look at the pictures I have of the silver side skirts and found a number of holes tucked up along the upper inside edge. They don't show too well in the pictures of the black version.
Per my conversation with the manufacturer when I first enquired about their products I asked if it had to be screwed into the stock pieces, the answer I received was that it wasn't necessary but an option.
I'm personally of the belief that the adhesive itself will do an adequate job of holding the side skirts all by itself, as it is pretty tough stuff.
I still believe that the S-Mann products are the best bang for the buck. They are currently (at time of writing this) the most cost effective solution offered in the US.
As far as removing them goes, why would you want to do that?!?
A little safety wire and patience goes a long way when it comes to cutting through adhesives. Don't go gung-ho and the pieces will be fine. Its the same method used for emblem removal from the trunk and boot but with upgraded materials.
Well I wasn't so much referring to strength on impact more the general strength of the Rear Valance during high speed driving. With there being a join in it's center you would imagine that would question it's integrity?
Once again I'm not too worried about it. With the amount of surface area dedicated to mounting they will be sturdy enough to withstand what most owners can put them through.
We are not running 200mph cars here, nor would I expect any valence to withstand multiple curb hits without having something to show for it.
-Dan
(PS: I'll post up the parts in the raw, now how many other vendors will do that?
