That's for stability so you don't tip over easily.
Send us some pictures of your ride and welcome to the club, lots of valuable information here.
Thanks Earl. But it is causing uneven wear on the tires. Does rotating the 2 rear tires help with the even-ness in wear. The reason is, my car only had 40K miles and I changed tires already.That's for stability so you don't tip over easily.
I assume you're talking about the tops of the rear wheels being canted inward. That's known as negative camber and as Earl says it was a deliberate decision by smart.Thanks Earl. But it is causing uneven wear on the tires. Does rotating the 2 rear tires help with the even-ness in wear. The reason is, my car only had 40K miles and I changed tires already.
The old school of thought was that tires formed a wear pattern and that changing their direction of rotation would speed up the wear of the tire. I have heard that is not the case anymore, but I would investigate further with a better source than me. I am sure someone will chime in soon with a more up to date set of facts. Thanks and good luck with your car. We all love photos here, if you have any of your smart.Thank you 1983JZR3W for the info. Why can't the rear tires be rotates between themselves, and likewise the front wheels between themselves?
I do in NYC. I am mechanically inclined and can do a lot myself and have Smart Owner friends that also will work on the car. Other things that I know what needs to be done but for lack of tools or lifts ect. , I take it to any shop that will do what I ask them. Such as any shop that services brakes can do Smart brakes. Any shop can change oil and filters. Firestone dose my wheel alignments. Any muffler shop can fix an exhaust issue. I would likely use the Mavis shop that works on my SUV if I needed suspension work that I could not do. Next level things that take diagnosis I use a High End Foreign Shop. At those times I am prepared to pay for that expertise rather than have a lesser shop guessing at the issue. 7 years ownership I am very happy with the level of repair coast.P.S. does anyone have their Smarts repaired or serviced by non-dealer Mecedes-Benz mechanics? I have always taken my car to a dealer; but it's getting unbearably expensive. Thanks.
