SO FAR IVE UNHOOKED MAP SENSOR, DID NOTHING BUT POST A CODE FOR IT. STILL NO RPMS. REPLACED PARKING PAWL SWITCH, NO CHANGE, JUMPED PAWL SWITCH, LEFT UNHOOKED, LEFT NOT PUSHED INTO THE TRANS, NO CHANGE, REPLACED TCM WITH KNOWN GOOD, TESTED WIRING TO PAWL SWITCH, CAP DISCHARGE, LUBRICATED SHIFTER MOTOR, REMOVED PAWL CABLE AND PHYSICALLY MOVED INTO UNLOCK AND STARTED IN NEUTRAL. NOTHING IS WORKING... ITS A 2011 FORTWO. ONLY MOD IS CUSTOM FRESH AIR INTAKE TUBE. NOONE I CAN CALL SEEMS TO KNOW ANYTHING AND I CANT FIND ANYTHING WITH THIS CODE ALONE. NO CHECK ENGINE LIGHT ON, CODE WILL CLEAR BUT COMES BACK AS SOON AS I GET INTO A GEAR. NEED HELP...
