1 - 15 of 15 Posts
Which snow tires are available for Smart Fortwo Electric Drive? I looked at previous posts on this subject and tires mentioned in those posts are no longer being made.
How could I find good quality snow tires for this monster?
2015 smart Fortwo Passion Coupe
I highly recommend Tire Rack for any tires. You can look up tires for your car, and get them delivered to either an installer, to you, or have someone show up and install them. I don't have a 453, but chances are someone has written a review on certain tires on Tire Rack.
I found out that theres a pretty wide range of tire sizes that will fit on the wheels. The factory tire sizes are really uncommon so try moving the sizes around until you get a more common tire size. It opens up more options and it's how I did research on the tires I am planning on buying. Try looking at higher profiles (60-70) for winter tires, I noticed theyre more common in higher profile tires.
Do you happen to know the tire sizes currently on your car? With the older model there were different sizes available from the factory depending which wheels you chose.
Sent from my REVVL V+ 5G using Tapatalk
The only Staggered winter tire setup I have found using the same brand and preserving the 20mm width difference between front and rear were Nokians from Discount Tire.
There will be no recommended winter tires for the Smart because winter tires are sold in sets of four, and Smarts run staggered setups for safety.
The 453's TCS is pickier than the 450 and 451; I would not recommend a '4 square' winter tire setup on it.
I explain more in this post: Snow tire size recommendation
2017 453 Passion ED/EQ
Helga, if you have any local tire shops nearby, they can be highly competitive and will do their very best to find what you need. Especially the non-chain owners can be an excellent source of info. 😥Unfortunately, if you show up for a quote, you might (sadly) want a male person to do the talking. Over-the-phone and female request for prices may be higher. Especially in the chain stores. :cautious:
1 - 15 of 15 Posts
