This is between me and a Youtuber called Carquestions. I commented to him because he specifically mentions in the video that he could Not find the gap size for his spark plugs in the owners manual.
John Phoenix
19 hours ago (edited)
I have a 2008 Smart Fortwo Passion Cabrio. In my manual it says on page 300 under Electrical System "Electrode gap 0.035 in (0.9 mm)" so that's what I'm using. My new plugs are Autolite Iridium XP, for $8.00 US dollars each. These are Not Pre Gaped so if you buy these make sure you have a spark gap tool and know how to use it. All 3 plugs were factory gaped way lower, you'll need to increase the gap to 0.035.
carquestions
7 hours ago
Autolite says they come pre-gapped at .032" so I wouldn't bother changing them
John Phoenix
4 hours ago
@carquestions My main point here was to let you know where the info is found in your manual. I think you are mistaken. The box on these states, quote, "Important: Check spark plug catalog for proper application, torque specs and gap setting. Set gap before installing" No where on the larger box that contains 4 plugs nor on the boxes of individual plugs does it say they are pre gaped. Also, why would you Not set the gap to the proper engine specs? To me, that sounds like asking for trouble.
carquestions
3 hours ago
@Divergent Droid The box might not state it but it states it on their website - also when making them they have to set them to some initial setting it stands to reason it wouldn't be random - and .003" won't make any difference at all and trying to move the ground electrode .003" on all 4 plugs is more of a risk than leaving them alone
At this point I figured it best not to reply back to the guy because all my years of changing spark plugs in my own car taught me to always properly gap your plugs. I think they guy is giving very bad advice but I didn't want to start a fight with him. He ignores what the box does state. Of course every spark plug maker is going to gap them to something. I think he's both wrong about not gaping the plugs correctly (I see lots of folks say to gap at 0.036) and I think he's wrong about gaping the plug will be "more of a risk than leaving them alone". What do you guys think? Who's right? Thanks.
I also see a lot of folks telling people the 451 takes 3.3 quarts of motor oil. I just changed mine and at first it looks like that may be correct because the dipstick is "Full" but all the oil is not down in the system yet. After running for 5 minutes checking the oil again you see it is not full. Adding the other .4 quarts tops it up proper to the manual specs of 3.7 quarts and now it is truly full. (this includes pre-filling the filter as the filter instructions suggest)
John Phoenix
carquestions
7 hours ago
John Phoenix
4 hours ago
carquestions
3 hours ago
