…were the old plugs dirty/oily in the thread area???
…go back when it was normal…
…we are talking about a 451 model???
jetfuel…we’ll wait
jetfuel…we’ll wait
Springs are definitely in place, as I removed the bottom boots and checked the internals for cleanliness, corrosion, and broken spring, no issues discovered. I'll try the plugs.…put the old plugs back on….
….make sure there’s a spring connector at the end of the plug boot….I got one come off and ended resting on top of the piston….not an easy rescue…
jetfuel….see what happens
…if it was running fine before the plugs why make your life harder???
…if crank sensor is bad it will not even fire…magnetic pick-ups (monopoles) don’t kind of intermittently fail …they go open circuit thus hard fail…seen them fail after a heat soak … you can measure resistance cold and then again after it develops the failed symptom…
…lifting the body only by lifting points makes getting to the plugs a piece of pie…
jetfuel…LUK
What plugs did you use? OEM Denso.
Where did you get them? Reputable supplier.
Did you use antiseize? Nope.
When installed, where you careful about cross threading? Absolutely.
A piece of tubing, stuck on the end of the plug, makes initial install easy.
