1 - 8 of 8 Posts
Has anyone had to replace the cover for the in-door speaker? Mine cracked and I was wondering how to get it off. Does it thread, snap-on, bolt in, or what?
Thanks in advance for the response.
If I remember correctly as done by one of our early adopters, the speaker cover is part of the bigger door cover and that the way to remove it is to dremel it out.
Them stock grills have heat welded studs you have to snip to get them off there... Once you get them off , you can screw on any New ones you want to put on...
That was a good slide show... To bad I never seen it before...? I did mine about the same way. Used my left & Right Side Cutters, and just used bullet conectors for the wires.
1 - 8 of 8 Posts
