I have a 2014 Smart Fortwo Passion (which I'm LOVING) but I'm having this weird issue. When you push on the accelerator, there's what sounds like a "spinning" squeal from the front. I can't tell exactly where because it only happens over about 25MPH, but it seems like it's coming from around the wheels. It only happens when you hit the gas. As soon as you let up or press the brake it stops.
I had the car inspected before I bought a month ago and was told it was in excellent shape. The squeal developed about 3.5 weeks ago.
I found enough info to spray a silicone lube onto some of the front wheel bushings, but it didn't help the issue. I'm not experienced at all in cars so I'm not sure what else to look for. Has anybody experienced this issue/have any idea what could be causing it? Other than the noise, the car drives great.
