Put the front up on ramps.Always wondered exactly where that brake light switch is?
These 3 photos show 1) Lower front under panel by unclipping at front and removing 10, 10mm screws/nuts. 2) Remove smaller under panel by removing 2, 10 mm nuts - note small section that folds back to allow for clearance around A/C lines. 3) Brake pedal carrier, underside cover, is removed by releasing latch, at rear of cover- end where drain is located, and gently pulling down on back of cover. There is a sticky seal on the cover which will release as you pull. (Good idea to wipe any dirt off of cover before performing this step to keep sticky seal from getting contaminated.)
