So--
I was coming up to a red light, in 4th gear. I shifted down to 3rd. The display didn't update and I didn't feel the gear change, so I attempted to shift it down again. I had to continue stopping and at this point the car started bucking like a stalling manual shift.
At this point, it stalled, so I decided to try and start it again-- because in a manual you could normally just kick it up again and go.. Well, the car didn't even TRY to start. Silence. The battery is new, the electronics work fine.
I turn the car ignition where I'd normally start it. I shifted down to D and then slid it to the manual gear shift position, it read "1". So I tried changing the gears, and it then shows "3", where it stalled.
I brought my Smart in to get a new clutch, because it made sense.
Now I learn that it's a problem with my Transmission only moving into two modes.
Could my transmission be seized?
Could I fix this rather than replace it?
450 or 451?
Sounds like one of the transmission motors is bad. They can be cleaned but you'd have to see how bad it is - if that is even the problem. Is the clutch actuator working OK? :)
451 transmission motors are at the top of the transmission, under the air intake plumbing:
So the motors are working on the transmission-- what's happening is the cable controlling the gears is only moving two positions, P and R..
hehe, yep.
well, we're getting a visit from a Transmission specialist tomorrow morning. So we're going to see what happens next :(
