1 - 4 of 4 Posts
2016 Steering wheel has gotten off center. Seems to be a rattle coming from front somewhere. Car doesn't pull to either side, nor any damage too the wheels and tires. Anyone else have this problem? Taking it in tomorrow to have it looked at. I've also had some issue with it shifting out of park. That was before the steering wheel was off centered.
Made a trip they will need to keep it. The alignment was off, tie rod's where loose. Here is some info I found out
1. Steering wheel and noise - tie rods loose is the cause and will need an alignment.
2. Gear wouldn't always shift out of park and would pop - they said there is info about grinding it down or having replaced, sounds like they will replace it.
3. Bluetooth connection- they claim there is an updated daily will install! We will see if it helps
4. Was informed there is an update to the ESP traction system and they will install it too
That is all I know right now.
1 - 4 of 4 Posts
