1 - 20 of 31 Posts
A friend asks if I am not adding to the weight of the vehicle by buying with the stock steel wheels, rather than the aluminum wheels.
I read the following online and it made me wonder.
"There are multiple examples of steel wheels with weights essentially equivalent to aluminum wheels, including:
The Chrysler PT Cruiser uses a 15 x 6 wheel that in steel weighs 17.0 lbs. while their aluminum counterpart is 16.9 lbs.
The 16 x 6.5 base steel wheel for the GM Cobalt/Ion is 19.2 lbs. while the aluminum counterpart is 18.9 lbs.
The 16 x 6.5 steel wheel for the Chevy Malibu weighs 19.2 lbs. while the aluminum counterpart weights 18.9 lbs.
The 16 x 6.5 steel wheel for the Renault Megane weighs 15.9 lbs., while the aluminum counterpart weighs between 16.5 and 17.6 lbs.
As shown in the above examples, styled steel wheels do not necessarily have a weight disadvantage and in some cases can be lighter than aluminum counterparts. It is important to recognize that wheel weight is very dependent on the specific styling. The OEMs are now directing stylists to control wheel weight by giving mass targets for wheels to the styling studios. "
http://www.steel.org/AM/Template.cfm?Section=Media_Center1&TEMPLATE=/CM/ContentDisplay.cfm&CONTENTID=16133
Does anyone have the weight of the stock wheels compared to an alloy wheels such as offered on the Passion configuration. Thanks.
Haven't had time to weigh the wheels yet. But from what I've seen, steel wheels are generally not lighter than OE alloys. Compared to some aftermarket wheels, the "may" be. All depends on how the allow wheel is made. Less expensive wheels tend to be heavier because of their manufacturing techniques.
Senior Smartie
In the above examples where there is such a minor difference (like the difference of whether you weighed before or after lunch.....LOL!
Why the concern?
wanted to confirm to the inquirer (my friend) whether the smarts are using the latest tech steel, I guess. or whether I was smarter than he...
you guys are silly
acting as if a few ounces of wheel weight is going to make any difference on a car that can barely hit 90.
Areodynamics, sprung wheel weight, air filter replacement are all such nominal issues when dealing with a sports car in city driving let alone an econo-box. Get the wheel you like the looks of....geez
And please dont let me catch you with a scarf and racing gloves on driving your Smart...I may take a video of you and post it on youtube
Yeah, I'd like to see that info as well.
Nice to have some quantifiable values around here - just as a baseline, if nothing else. It would be handy to be able to compare aftermarket wheel weights (which are readily available) with the stock units (which seem to be state secrets) when making purchasing decisions.
Jeff in Atlanta
Wheel Weights
Here is what I know on weights on Passion wheels
O.E. Alloy wheels
15x4.5 front 10.5 lbs/ 24.5 lbs with tire
15x5.5 rear 14.5 lbs/ 31.5 lbs with tire
I believe most people are buying the car for now as a 2nd, 3rd or even 4th car and just want it because it is different and want it to look cool. So just find a wheel that fits good and looks great and call it a day. I don't believe the majority will mind if you lose 10 mpg because of heavier wheels and or tire packages all though some will. For those of us who don't we will Drive it and enjoy it and try to help both sides!
Darren (WSI) 480-222-7213
Thanks!
Now for the steel wheels...
Anyone?
This will be our daily driver and sole 4-wheeled vehicle (I have a motorcycle, but it doesn't get out to play too much, as I can walk to work). We'll be doing 99% city driving, and mileage is important. I'm trying to decide if a Pure with steel wheels is the way to go, or will the Passion with the alloys be a wiser choice (ceteris paribus)? Or perhaps the Pure with aftermarket alloys? Though I don't think that would make economic sense.
And we tend to keep cars for a long time, as in we are currently in a 1995 vehicle which we bought new.
So the goal is to have a car with optimal MPG balanced with fun-to-drive qualities, so lighter wheels/tires on the corners would win on both counts.
The current car has Konis and a few other performance enhancing mods, so I do like to modify, if it doesn't introduce too many tradeoffs in the MPG side of things.
That's why unsprung and rotating mass items are so intriguing to me.
Jeff in Atlanta
One thing I have never seen discussed is rotational inertia. Since the wheel rotates, this is important and since inertia is a function of mass and the distance of that mass from the axis of rotation, not all 25 pound wheel/tire combinations will be the same.
I suspect that for a given wheel diameter there isn't a huge variance, though, and that could be why it isn't discussed. But I also suspect on a car this little, a little bit of variation can have a significant affect on performance (not just 0-60 times, but also on mileage).
I would really like to hear from someone knowledgeable on the subject to tell me what the difference is in the rotational inertia of a 15 inch wheel/tire and a 17 inch wheel/tire and how that might impact performance.
geosynch
There should be other weight differences between the pure and passion. such as manual windows and mirrors vrs electric. and is the solid roof heavier or lighter than the transparent one?
I hate to keep referring to this web site, but www.yarisworld.com has a fair amount of info on this subject. It seems some wheels are worse than others, as more of the weight is located towards the outer perimeter of the wheel (for aesthetics), which makes acceleration worse. I imagine this is a bigger issue with stop & go city driving vs. highway, constant-speed type driving. I do know that the general consensus (based on data) over there is that bigger wheels are worse than smaller wheels. If you want to maximize MPGs (and save money on new wheels & tires), stick with the smaller ones. Stay away from 16 & 17 inchers - way too much weight and rotational mass way out there on the outer radius. But as one hypermiler there said, it would be a waste of money replacing what you already have with something lighter, as you would never recoup that money in MPG savings. Replace them for appearance, but note simply to save gas. Still, do the research first and make informed choices. That's what I'm trying to do.
And Tirerack has a report on a test they did with various weight wheels re handling. Turns out that the lighter the wheel/tire, the better. So there is a performance dimension to this as well.
Macaw, I think a couple of people around here were weighing their cars which had different options, which is at least a start. Still, I'd like to see a more comprehensive treatment of the subject. Yaris people yank back seats for weight savings (and weigh them when they do), for example, but we don't have much to yank in a Smart, and Smart owners don't seem to be as obsessive over the MPG thing for some reason. Still, I haven't seen a comparison of the weight of a stock Pure (okay, with AC) and a stock Passion and a stock Cabriolet.
And surely someone has pulled their steel wheels and could throw a couple on a scale? A dealership out there?
Always hoping.
Jeff
geosynch
They probably would be more aerodynamic, but I doubt it would be measurable when it comes to MPG numbers. I'd still like to see the weight of the Pure wheels - that is still the missing piece of this puzzle.
Jeff in Atlanta
1 - 20 of 31 Posts
