Have a 2011 Smart with 92,000 miles. All original except tires, air filter, coils and plugs. Just started making a strange noise when the brakes are applied at lower speeds. Sounds like the horn, only not as loud. I disconnected the horn as an experiment but it still does it. It is not a continuous or consistent noise either. Just happens a few times per commute and at lower speeds. I can tap the brakes and it usually stops. Braking ability has not suffered. Any idea where I should start looking? :shrug:
Thanks, Brett
Thanks, Brett
