81 - 100 of 120 Posts
Discussion Starter · #82 ·
I’m waiting to see if there are any con’s to this product
I still have not hit the challenging twisty roads that I will blaze through this driving season, but my daily driving has been so much more pleasant. When it's time to hit the Tail of the Dragon again I feel I will have adjusted to any handling difference or I would just pull the buffers for the weekend. So I see no harmful side effects to this point. I installed them the day this thread started.
Discussion Starter · #84 ·
Motor vehicle Light Automotive tire Automotive lighting Vehicle
A 451 Brabus owner on Facebook tells me he also has the installed in the rear and that he really likes the ride feel. He is also running 205/55 15 front and 225/45 17 rear tires.
Wheel Tire Car Vehicle Hood
As Arby's says "He Has the Meats"
Discussion Starter · #87 ·
Is the consensus to put them on the front, rear, or both?
A front harshness reduction is what my initial desire was, and the spring
Buffers accomplished that. So the front is a must do in my opinion. Now whether there is a benefit to also have them in the rear and what type Shore rating would be best application would take some trial and error. But the owner in California that put them on all four springs reports he enjoys them without any negative effects.
Searching ebay for size "D" RubberShox, I found only blue/plus (5000-6000lbs), black/pro (5500-6,500lbs), and green/super (6000-7000). Red or orange (the softest at 4,500-5,500lbs) didn't come up in several different searches. I didn't actually try to order direct, but it seems they are out of stock.
I found this
The smallest size was 3-3.5" diameter. Not sure if this would work as the size doesn't match but might overlap. The website indicates that they can make (pour) custom spacers. These are stated to be for racing applications which may mean that they are too harsh for street use or maybe it,s legalese to limit liability.
I found this
I wanted to try some on the rear and ordered from Rubbershox. They cancelled my order due to being out of stock so I ordered the blue plus D size and will see how that works out. They said they will fit and the hardness seems to somewhat overlap.
