1 - 3 of 3 Posts
2016 453 gas.
Both taillights work when you step on the brakes as does the third brake light, but not when idle. When i turn the light stalk on- the tail lights turn on for a split second then click off. My question is what could be the cause of this?
Fuses aren't blown. I don't know which relays to check and the bulbs are not blown. Thanks in advance!
two questions....
1) I'm assuming since you said the bulbs aren't blown, that you have the non-LED taillights?
2) when checking fuses, did you check the panels both in the box under the service panel as well as the one in the glovebox?
Correct. Non-led. Not blown
I checked the fuses in glovebox panel, but not the service panel. Which fuses would I check in the service panel?
1 - 3 of 3 Posts
