Tan flat cable wire on radio 2010 Passion
I had to remove a stuck cd in the cd player and in the process of pulling the radio, the brown/tan flat cable wire that connects the control panel to the interior circuit board came apart. Not came undone and needs to be reconnected, but it pulled apart right where it attaches to the board under the radio housing. Is that tape wire integrated or does it plug in on both ends? I know it plugs into the back side of the control panel. It's the board under the radio where the tape wire came apart from the connector. If all I need is a new tape wire with two connectors I'm feeling much better...on the other hand, if the wire is integrated...I'm in trouble...
ANy help would be much appreciated.
