1 - 12 of 12 Posts
Could I put the larger wheel and tire size used on the rear of the Smart 453 Cabrio on the front of the car, so the tire and wheel sizes are consistent? If so, are there any ramifications to doing so?
That has been a common practice on the 451 smarts but not so on the 453s. Most folks are satisfied with the handling with the staggered tire size. You could install the wheels and tire size found on the Prime model that also has a the lowered suspension.
The 2017 Smart Prime Cabrio is the vehicle I was going to do it to. With same size tires and rims all the way around, I figured my 5,000 mile tire/wheel rotation schedule would be more efficient and it would extend the life of the tires.
2008 Passion, now a 2016
Okay, I have to jump in with my vote... Don't do it. Without going into a lot of detail here, I'll just put a link to my reason. Mixing front and rear sizes outside of the smart factory specifications on the 453 is a recipe for traction control disaster.
Just sayin'
Jim
Just sayin'
Jim
No......... that's great advice, the last thing I want to do is really screw something up in my baby.
I should add that turning Traction Control off in the 453 is not as simple as pulling a specific fuse, like on many other cars.
As I understand it there are a couple fuses that must be interrupted and the result is you loose all safety features, including anti-lock brakes, cross-wind assist, and more. If you could break out the TCS by itself, I'd take that risk.
Jim
I totally agree, don’t do it. As the owner of two different smarts over the past 9 years - 451 & 453 - it’s really not that big of a deal living with different size tires front/rear. Many have done the switch on the 451s but things are different with the 453s. Relax and enjoy the handling of your Prime.
Discussion Starter · #8 ·
Thank you. I won't be doing it.
Discussion Starter · #9 ·
Jim
I don't want to do that. I won't be doing any modifications.
1 - 12 of 12 Posts
