81 - 99 of 99 Posts
Hi Tom,
Thank you for the quick reply.
I like your hitch mount deign.
I would like some photos if you don't mind. Please send them to j o e i n n o @ me . c o m
I see that there are lateral braces on the tow bar sold at the German place do you think your design would benefit from additional bracing. The braces are int he installation manual on page 11/15.
Thanks again,
Joe
And some folks never remove that "Do not remove under penalty of law” mattress tag.
Hook up that trailer and get those smart 453's off the sidewalk, live life on the edge...
Two kinds of folks on this planet: those who look for problems and those who look for opportunities. The ratio, it seems to me, is somewhere in the neighborhood of 100:1.
I think it's funny when people say "oh, that can't tow" just because of it's rated maximum load. Just the other week i loaded 7 bundles of GAF architectural ridge vent into my 453, split between the "trunk" and on the back of the passenger seat. About 450 lbs. worth. Plus my 230-ish lb. self. I will say it was riding quite obviously a bit lower than usual, but the engine and my 5-speed manual had no issue at all moving it. Didn't even seem to break a sweat pulling out from a dead stop.
Also, the maximum load the vehicle itself can carry (often called payload) is not what the vehicle can tow in trailer weight. Example: My parents' full size SUV has a payload of 1,700 pounds, but a trailer weight capacity of 9,000 pounds.
You still shouldn't exceed your payload (gear, passengers, tongue weight of trailer) but your payload doesn't necessarily determine how heavy of a trailer that you can carry.
There is also this: towing is probably less than half of the consideration. Stopping is the bigger hunk. And often, much more important too. Any one else slid through an intersection with all four wheels locked up with the trailer calling the shots? Me towing a Hobie 33 with a Jeep Cherokee with cops tidying up an earlier accident at the bottom of the hill. I remember it quite well.
It's a grand luxury to copy off the other guy's paper. Mucho thanks to the several folks who offered designs and how-to's on building a hitch for the 453 -- and especially to Everyready_Tom who provided suggested materials, dimensions, and pictures, including a bunch sent to my e-mail. Here's the final result. I'm a little concerned about he torsional load on the old bumper and its mounts. There's quite a bit of flex. Of course, depending on the material, flex isn't necessarily bad, but I may consider a bit of a redesign to cope with it anyway. Finally, I think the reason that no one has yet manufactured a hitch for the 453 has more to do with the lack of a good anchor on the car itself, rather than limited demand. Since I built mine to carry bicycles, while very rarely pulling a very light trailer, I'm hoping for the best!
62088
62089
62090
62091
I was tired of waiting for a hitch so I made on this last weekend.
I was tired of waiting for a hitch so I made one this last weekend.
2016 453 Prime Smart car1 1/4" receiver hitch
It is a 1 1/4" receiver hitch that came out very nice if I do say so myself.
I removed all the plastic and found the bumper was very easy way to install my hitch too.
5 3/8" bolts washers and nuts
3 short pieces of 2 1/2" X 1/4" flat stock
1 6" long 1 1/4" receiver tube from Tractor supply
1 3" C channel 35" long
1 can of paint
7 Rivets
Bolting the 3" C channel in the existing bumper was perfect dimension for the 2 1/2" X 1/4" flat stock
To go down just in behind the muffler.
A little cutting and welding and I was ready to go.
Hi Tom! Thank goodness for your ingenuity! I would sure appreciate any information you could provide regarding your fabrication on your trailer hitch. I have a 2016 and you seem to be the hero for this great need in the smart car world. Much appreciation in advance. :)
Danna
[email protected]
1 can of paint
7 Rivets
I want to thank you for your post,I like you wanted a hitch for my 2017 Smart and with one not available and no one willing to fabricate one for me I decided to make one myself followi your plans
I did change a few things,the 3” Channel iron I turn the other way and weld a 3” x 9” 1/4 plate to it with 3x3 plate ends , total cost for materials was $50
1 can of paint
7 Rivets
Discussion Starter #98
Found one.
Site is in German, but any online translator will work.
Anhängerkupplung smart fortwo Typ 453 | fortwo 453 ab 2014 | smart | Produkte | MisterDotCom
$590 US
Misterdotcom is a long time smart accessories provider.
Just bought one, it arrived yesterday. It looks rather straightforward, you lose the rear bumper and the hitch takes it's place. Only problem, the instructions are in German, not a real problem for the hitch but there's a wiring harness included.
Can or how does the hitch work with a bicycle rack? As that seems to be the most requested application for a hitch on a smart?
81 - 99 of 99 Posts
