went to get some ar walmart and all they had was GL5. is that ok to use and what do those numbers mean
For all those people who find it more convenient to bother you with their question rather than search it for themselves.
80 four door?? They stopped production on Corvairs in 1969 ?? I did a few slicing and splicing of Corvairs myself. Had a 1965 front and a 1966 rear convertible only I forgot to natch the plates. Police had a few questions on why the plates didn't match.. Both plates were in my name, but still....They were fun to work on.i had an 80 four door and a 65 monza. loved the monza. while i was in the air force a major friend of mine had a project to take a wagon then cut the back door section out all the way across then weld the two halves together and stuff a corsa engine in it. needless to say we did not get it done because nasa grabbed him to develope the water purification system to take pee and turn it in to drinking water.
If you have any questions about tranny fluid you can ask Caitlyn
I had a couple of Corvairs. The most fun was a 1965 with a small block 327 cubic inch 365 hp V8 where the back seat used to be. Sneaky fast but the trans was fragile and the input shaft would break if you looked at it cross-eyed.I had a few corvairs, highest count was 27 at one time. my favorite was my 66 Corsa with the 140 motor. Those carbs were a pain but when they worked right....
Same with my 64 Rampside.. easier to put the motor in, especially with the crown conversion but still tended to break things when you jump on it hard.I had a couple of Corvairs. The most fun was a 1965 with a small block 327 cubic inch 365 hp V8 where the back seat used to be. Sneaky fast but the trans was fragile and the input shaft would break if you looked at it cross-eyed.
