1 - 3 of 3 Posts
has anyone heard if the tranny can be reprogrammed? The reason I ask that is because when in auto (I am a gentle driver) both 1st and 2nd shift way to early unless you drive hard or use the paddles (but there are times you need "auto").
I am sure it can be reprogrammed with a MB Starr computer and an uplink to MB Germany. Probably not cheap either. If you hold your foot all the way down on the gas pedal, it will delay the shift.
1 - 3 of 3 Posts
