1 - 18 of 18 Posts
Hey everyone,
I just saw the smart car at the Tulsa, Ok road show.
I have a question about the car that I hope someone here can answer. I am a performer/entertainer and in some of my shows I use what is a called a suitcase table, it is basically a case that holds my props and that opens up to also be used as a table.
I am wanting to know the height of the trunk area so I can know if I would be able to transport the table in the smart car.
When we looked at the car I am pretty sure it will be wide and deep enough, but I don't know about the height, going on looks (didn't bring a tape measure) the height might be cutting it close.
Thanks
RLove our drive down here is next Wednesday the 24th at Round Rock or Dell Convention center (still got to google the address) ---- And likewise , I will try to remember a tape measure.
Alright, we had our test drive today, and they had a demo car sitting out for everyone to sit in and check out.
I measured for usable space, and not to the very limit assuming that you'll need to slide something in straight on. And, the seats in front were leaned back a bit like you probably would have them. With that being said - the measurement across was 40", 28.5" tall, and 11.5" deep, (there is some slop in this figure like I said - you could move the seats forward and crank them up more vertically, and pick up several more inches if needed.
I hope this helps.
Randy
Smart A**
Based on RLove's numbers that will get you about 8 cubic feet. To reach the 12 cubic foot number I've seen, you'd have to move the seats forward another several inches.
The other four cubic feet
If RLove's numbers are based on measuring to the top of the seats, I'm pretty sure the other four cubic feet is the space above the seats up to the roofline.
I hope this helps.
Randy
So the question is . . . where are the extra 7" of length they added?:confused:
The front end of the smart was lengthened a tad to meet new pedestrian crash standards. You'll notice raised hoods and front fenders on many other new-for-2008 models for the same reason. (The new Honda Accord comes immediately to mind.) While they were at it, smart also added a bit to the passenger compartment and to the rear storage area. The rear storage on the 451 is significantly larger than on the old 450 model. That being said, two shotglasses is much more than one shotglass. Smart's "trunk" is still tiny. That's part of its charm. Perhaps a bass amp will fit if you fold the front seat flat. I've seen photos of amazingly large items crammed into the rear of a smart!
There is no designed-in storage space under the front hood of the smart. It is for mechanical access only. The radiator fluid, windshield washer fluid and headlight bulbs are all easily accessible from there.
Based on what I've read, the Canadians have difficulty when it comes to accessing the headlamps. Hopefully this has been addressed in the 451 for the USA. ;)
1 - 18 of 18 Posts
