1 - 4 of 4 Posts
A couple of weeks ago I drove our other car while my wife drove my Smart ED behind me. I noticed that the headlights of the Smart were uneven in brightness. I couldn't figure out whether it was a misaligned reflector orientation or actual light power difference.
So, I took it to the dealer and they confirmed my observation, but didn't have a fix. Even though they replaced both headlights, the issue persists. They said they would keep an eye on their database if my issue comes up and a solution with it. Bummer.
Anyone experience similarly uneven headlights?
can you take a pic of the beam on a wall?
they replaced the headlights? did they reuse the bulbs? maybe swap the bulbs side to side?
also try measuring the voltage with a meter... could be a corroded fuse or bad ground
there was a fix for cars that burned out a lot of headlights by putting a resistor in the line to drop the voltage a bit. that may be what you are seeing. A voltage check should show if you have that fix installed.
1 - 4 of 4 Posts
