Has anyone tried the Vololights with their ED? Looks like a cool option to trigger your brake lights when regening.
Not CANBUS compatible...![]()
You can use a fuse block of some sort to pull 12VDC power from the motorcycle to power these devices without setting off false alerts in your mototrcycle's monitoring system. Customers have recommended fuzeblock.com with good results. A simple Google search for 'CANBus fuse block' will net additional options. Check with your dealer for installation of the fuse block
https://vectolabs.zendesk.com/hc/en...llation-of-Vololights-with-CANbus-Motorcycles
