All steps below were done without dropping the engine down, excluding where i had a bolt break and took the passenger side mount off the block to drop it a little to get my welder in there.
1. Remove belly pan bolts 10mm - one on each side of the car - this gives accesss to the lower radiator hose
2. loosen radiator lower clamp and pull hose off - becareful as the radiator end is aluminum and easy to bend
3. jack rear of car up and use jack stands
4. use a flat blade to loosen the belt/ pulley cover locks (these are on frame behind the tire, i did not take the tire off to gain access)
5. remove pulley cover
6. take passenger tire off
7. take an e14 socket to the belt tension pulley with a LONG extension and remove it,
8. remove belt fully once tensioner is off the motor
9. take a 10mm wrench and a screw driver (stick screw driver in a pulley hole to stop the pulley from spinning) then loosen and remove all 4 pulley bolts.... use same method to tighten the bolts
10. i used a long pry bar to pop the pulley off
11. take a 10mm deep socket on a 1/4" drive ratchet and remove the water pump bolts
12. there is one 13mm socket that will be used on one bolt.
13. pay attention to where each bolt goes as some are longer than others.
14. remove water pump
15. clean surface with a razor blade till it feels "smooth" with your finger
16. use brake cleaner and a rag to clean up the surface of fine dirts
17. install new water pump (it uses an o-ring style gasket so no silicone or other gasket sealer is needed)
18. tighten all bolts (be sure careful not to strip any)
19. begin assembly of everything you removed
20. bleed the coolant system and enjoy
