21 - 23 of 23 Posts
water in the passenger floor well in Hawaii
The AC condensate drains thru the passenger footwell that would be my first look. The tube is light and very easy to pinch, kink or pull apart the conections
This photo shows the drain tube. Battery vent clear tube/ AC drain Black Rubber tube that can be taken apart by hand. The forward end of the hose fits onto a nipple on the bottom of the "heater "box.
karl
can i remove the black hose easily and put i back easily? does it just slide on and off thought i would remove and blow air thru it to see if is it is clear or pluggedlmk
Traced the water to under the battery. Pulled the clear plastic hose out and the water drained on the ground. This hose appears to be a battery vent. Your photo was helpful but could you elaborate on the a/c hose? I was going to blame the roof for leaking because my Smart is a 2008 rag top and who knows how long the water has been accumulating but we have been running the a/c because of the heat and humidity lately. Thanks
21 - 23 of 23 Posts
