We’ve given this a test run and all appears to be fine. 2011 Smart Fortwo Passion, automatic trans.
We bought a tow dolly that has disc brakes. $1600. We do the exact same procedure you would to to flat tow, from the manual. Manual battery disconnect switch.
We’re towing front wheels up. Our mechanic could find no reason why we couldn’t tow this way as long as we followed flat tow procedure and disconnected battery while towing.
We’ve test it over 60 miles and so far no issue. We are using an Acme Ezee Tow dolly and no issues with clearance loading or unloading.
We did have to work on where the strap tie downs best worked on the small tires. Turns out 10, 12 and 3 suggested strap placement left the 3 o’clock strap too loose. The final placement so far is 10:00, 11:30 and 1-ish worked!
Pulled like a dream. Didn’t ever feel it and it was a windy day.
66585
Pulled like a dream. Didn’t ever feel it and it was a windy day. View attachment 66585
Do you put the transmission, in neutral? We were following this guy, out of St. Louis. He had all 4 tires to the ground.
66618
The manual says this:
Do not flat tow the vehicle with the front axle raised. Doing so may cause serious damage to the brake system which is not covered by the smart Limited Warranty.
But it's never been explained exactly what damage is supposed to happen. If the car wakes up during the tow it could freak out and lock up the brakes. But if the battery is disconnected it's not really any different than flat towing, save for the front wheels not actually moving. Looks like you just confirmed that such is the case!
I’m using the same tow dolly for the first time. Only thing I’m nervous about is that it moved back from the front tire stop and sat in between the two tubes. It seems to be tracking fine.
