Good morning,
As I continue on my quest to get all issues corrected with my new to me 08 passion coupe to pass MD inspection I have noticed no illumination on the floor gear shift gear position. I searched YouTube and every smart I saw had a yellowish backlight helping to display what gear the car is in. When I removed the center floor consoul I noticed there is an empty spot for a bulb under the center consoul. I have searched here and online, but turned up no size, or bulb picture info. Any knowledgeable smarties that could provide this bulb info would be appreciated.
FYI I was already removing the center floor consoul to check my non functioning 12v plug on the lower dash. I found the wire disconnected to the plug, but still no juice when reattaching the wire. I also checked the 21 fuse and it looks good, so any other ideas on what to check to get the power outlet plug (don't know proper name) working would be helpful.
Thanks in advance.
Thanks in advance.
