1 - 11 of 11 Posts
I have a set of Newton Genius wheels and Tires I will no longer use. Cost about $1000 new. Tires are General Altimax P185/55X15. Have about 4000 miles on them. NO TPMS..!! $500 or Best Offer. No Shipping...but will work on pick up in New England. I live in Keene NH
Cross you fingers..maybe. I drive to FL in December after Christmas...East coast.
It won't do you much good, as you would then need to take the bad tire off of the rim, and reinstall the good tire onto the rim.
If you carry a fully mounted tire and rim, then you only need to remove bad tire/rim, and install the good tire rim.
To do all that, you need a jack, lug wrench, and maybe a couple of blocks of wood to use as chocks.
Another option, as long as the leak is not a huge hole in the tire... try the onboard tire kit, it has sealant and a pump to air
up the bad tire. I would also recommend a can of flat fix, or something similar... to use incase the OEM tire kit does not work.
Cheers!
Please note...
Author is not responsible for any and all disputes that are a result of his post, including but not limited to technical content, rumor, lies, jokes etc...
TC, as long as your intent is good... I believe she will forgive you!
Please note...
I currently have my original rim and tire set at the bottom of one of her closets. She threatens to wash my Smart with some lighter fluid and a match if the are still there this spring. So I couldn't horde another set.. Of course I could buy them and leave them in the bottom of one of his closets as this is all his fault anyway in spite of that pitiful disclaimer. Then all I have to do is find a couple of pristine Smarts with no wheels .... Hmmmmmmmmm.
..and why pass up a beautiful drive the NH.
I'll figger this car out
Would you like to sell your original wheel set? Then you could buy these.
These are my original wheels with 195/50 15 up front 195/60 15 in the rear. They have just been hard to find them inexpensive and to repair the few bends the have is just as expensive so I have been hording them. My Son gave me an idea this weekend to Carbon Fiber Wrap them. I could entertain that. If not for my current car, as I think I have designed the Harlem Edition away from these Wheels, I can see a Smart Build with these wheels as the starting point. So very torn on selling them.
1 - 11 of 11 Posts
