1 - 20 of 22 Posts
I just purchased a 2016 smart for two Pure . I would like to replace the rims and tires. I have called 3 wheel shops online and basically cannot get a pair of rims and tires to replace stock.
I would like to get 16" rims or if that's a problem...... Then 15" rims. The car Has 4 lug wheels.
I would like to know if i get 16" or 15" rims what should be size,offset or anything else i need to know. Same goes for the tires.
I do not want low profile tires.
I just purchased a 2016 smart for two Pure . I would like to replace the rims and tires. I have called three wheel shops online and basically cannot get a pair of rims and tires to replace stock.
I would like to get 16" rims or if that's a problem, then 15" rims. The car has four lug wheels.
I would like to know if I get 16" or 15" rims what should be size, offset or anything else I need to know. Same goes for the tires.
The standard rims for the 165/65R15 front tires are 5Jx15 ET32 and the standard rims for the 185/60R15 rear tires are 5.5Jx15 ET42.
5Jx15 ET32
https://www.oponeo.co.uk/steel-wheel/alcar-kfz-4003#20841146
5.5Jx15 ET42
https://www.oponeo.co.uk/steel-wheel/alcar-kfz-4004#20841130
The PCD on these rims is 4x100mm and the central bore is 60.1mm.
On the 453, instead of the standard 165/65R15 front tires and 185/60R15 rear tires there are a number of options open to you. One option is to fit 185/55R15 tires to the standard 5" wide front rims and 205/50R15 tires to the standard 5.5" wide rear rims.
Vredestein Quatrac 5
185/55R15 82H
https://www.tirerack.com/tires/tire...55HR5QT5&vehicleSearch=false&fromCompare1=yes
205/50R15 86H
https://www.tirerack.com/tires/tire...05HR5QT5&vehicleSearch=false&fromCompare1=yes
Another option is 175/65R15 front tires and 195/60R15 rear tires.
175/65R15 84H
https://www.vulcantire.com/cgi-bin/tiresearch.cgi?stock=22041&f=quatrac5_s.cst
195/60R15 88H
https://www.vulcantire.com/cgi-bin/tiresearch.cgi?stock=22066&f=quatrac5_s.cst
My preference out of these two options would be 175/65R15 front and 195/60R15 rear tires. I wouldn't go for 16" wheels as the ride is a lot harder due to the lower sidewalls.
Hey,
Jzchen,
Tirerack and a few others online were absolutely no help. I think they just are misinformed on the smart car. I am in the U.S. I would like to buy from a US company. I'm also not looking to spend too much. But thank you.
Injured again,
My 2016 smart for two has hubcaps.... I DONOT like hubcaps. I am looking for a black glossy or matte 15" rim. Like the vision 423 rims. Nothing more than a better look.
Big 453,
Some great info,but unfortunately none of the links work for me and it's not a 453 model. I have the smart fortwo pure.
I have been on the phone with numerous companies that tell me they donot have a rim that fits my car..
I have also used the configurator on many sites and it pulls up an electric model but no good.
Either way, if you know of any black rims that are not too high in price. About $100 each rim and $100each tire. Please let me know.
Discussion Starter · #7 ·
Jwight,. This is the first I'm hearing of this. I did buy in the US.
But not one website States that when I'm looking. Trim models come up under smart fortwo. Prim proxy passion or pure. I have the pure
What Jwright said is correct. All 2016 gas versions of the smart are the 3rd gen 453. Just so you know, tire companies most likely won’t recommend that you put the same size tire all around because the manufacturer didn’t so equip the car that way and does not recommend it to be so equipped. It’s a liability issue for them. Your smart already has the base steel 15” rims and you wish to have a different style. I seriously doubt you will find ones in the $100 range unless it will be on the used market and take-offs where someone upgraded the factory rims. With less than 10,000 ICE 453 smarts imported into the U.S. why would rim companies spend the money to develop a slew of aftermarket rims?
Big 453, Some great info, but unfortunately none of the links work for me.
Links now fixed.
You could use Renault Twingo III alloy wheels and run 185/60R15 tires all round.
Here's a listing on ebay.co.uk but it's collection only in the UK.
https://www.ebay.co.uk/itm/Renault-...Twingo&hash=item4693a820b0:g:iagAAOSw11BcB~jZ
The Renault Twingo III uses 5Jx15 ET38 front rims and 5.5J ET36 rear rims.
Renault Twingo III 2014-present
https://en.wikipedia.org/wiki/Renault_Twingo
Here's another listing, but this time for Smart 453 alloy wheels.
https://www.ebay.co.uk/itm/smart-ca...rentrq:df57e89e16c0a4e883b79c86ffdd7382|iid:1
Discussion Starter · #11 ·
Oliver B,
You are correct. That's probably why I can't find the runs Well at least I can see other options. I did see some for the 453...
Also. I have found a few great looking Rims for about 100 or so new..but not sure on the fit..
Big453,
Thank you for fixing the links. Thank you for all the help everyone. I will continue to look for some rims
Discussion Starter · #15 ·
Thank you everyone for all the help. Really!!! Jzchen<-Thanks....These rims and tires fit right on.
I had to wait because tirerack had to order the valves. They came in an hour ago and I threw them right on..
For anyone wanting to know. I purchased New tires,rims,lugnuts,locks,and TPMS valves,delivered to my door. $910.
1 - 20 of 22 Posts
