1 - 20 of 50 Posts
· 10Year+ Supporting Member
2009 Brabus Coupe
Did you know that the exhaust tips are just for looks? The actual exhaust exits on the bottom of the muffler can. Seems like a lot of extra work to me. Why not just use an exhaust like the early US spec Brabus?
This looks like the rear valance for the US 453 version of the Brabus. You should be able to order it by paying a visit to your smart Center's parts dept. You will probably have to acquire a VIN from a 2017 Brabus. Hopefully, your smart Center will have one in stock for you to copy the VIN. Very few US Brabus versions will be available.
A 453 647 05 00 Code: E56+P71
or
A 453 647 06 00 Code: A04+E56
E56 Daimler/Smart Brand
P71 Brabus Sport-Package
A04 Smart Brabus
Too sleepy to figure out which one is the right one. Can't tell from the picture, it shows the one with the exhaust holes.
Peace guys.
I think the OP wants the one without holes. I am assuming, now that I have some of my senses back, that it is the part number with sport package, not Smart Brabus.
If I could cut plasic as carefully as Stretch I'd be doing things on my own.....
Discussion Starter · #18 ·
I want the rear diffuser... I want it to look like this... if anyone can help in that effort, I'd appreciate it. Your sawzall body kit, while fascinating, doesn't help to answer my question.
It is also the wrong model of smart, the wrong look, and the wrong muffler.
Lol, it's a 450 duh. It's an example, not your specific part. It was in response to SmArtist00.
Probably one of my last EPC interactions, until I pay up to renew. :D
As far as I can see, the part wanted attaches to the lowest bumper piece, called TRIM BUMBER BUMPER, BOTTOM SECTION. I tried to check how many different part numbers there are for this...
(Suspense...)
3
A 453 880 03 40
A 453 880 13 01 (Note says use A 453 880 34 04 Yay, if true!)
A 453 880 34 04
Code P71 and A04 are mutually exclusive, but both point to
A 453 880 34 04 So if you have a Smart Brabus or Brabus Sport Package you have this part.
Noted just above A 453 880 13 01 is not available, and to use A 453 880 34 04, so we've narrowed it down to
A 453 880 34 04
and
A 453 880 03 40
SINCE YOU DIDN'T PROVIDE ME A VIN, I HAVE TO SORT THIS OUT PAINFULLY!...
P59 (Sport Package) points to
A 453 880 03 40
P89 (No sport package) points to
A 453 880 13 01
which is not available, so use
A 453 880 34 04
The concern comes down to whether your car has SA code P59 or P89.
If it is a P89, we are good to go.
If it is a P59, then you might need to buy A 453 880 34 04 (CHANGED FROM A 453 880 03 40) as well, because it is a different part number and I can't tell if they are interchangeable when it comes to attaching said part in question...
1 - 20 of 50 Posts
