Check the air in your tires 1st thing in the morning before driving the car.
Inflate to factory specs or even 2 lbs over spec. Factory specs are on a sticker on the driver's door frame. Do not inflate to the "Max PSI" number on the sidewall of the tire.
Enjoy a 3 or 4% increase in your range if they were (as is winter typical) underinflated.
If you are driving a gas-powered car, you can blame you winter mileage reduction on winter-blend gasoline. But with the ED, its battery temp and tires.
Discussion Starter #2
One other thing about tires and tire pressure. If you are tempted by your dealer to spend $40 to $80 to inflate your tires with pure nitrogen, you have a better chance or getting something worthwhile for that money by purchasing lottery tickets.
