i am going to remove the speedo and instrument cluster so i can work on the buttons to get the clock and traction to work. i read that you are supposed to grab the entire pod and pull it towards the steering wheel. there are four clips holding it on. i just wanted to ask someone that has done it how hard it is to pull off and if there was any thing else i should know.
thank you
thank you
