hi all,
I'm desperate.
Check engine light came on, haven't been hearing secondary air pump come on.
Pulled p0410 Code
Cleared codes
p0410 came on next day
Did lots of research here and replaced change over valve with new part #a0025407097
Still threw p0410 code
Found 50amp fuse for secondary air pump was blown..replaced it
Cold started now and it blew the 50 amp fuse again.
I'm guessing the air pump is bad? Maybe clogged line somewhere? Is there anything else that would be blowing that fuse when it tries to kick on the pump?
Stupid smart car!!!
Thanks!
I'm desperate.
Pulled p0410 Code
Cleared codes
Stupid smart car!!!
Thanks!
