Another update for this particular problem.
I drive about 400 miles since last report, and suddenly Engine check light is ON.
I check and see same P0410 error
So, I decide to do same - clean valve with carb cleaner, compress air back and forth in all openings, plus clean/lubricate with light oil and blow with compressed air all excessive oil.
In addition, I install a home-made filter from open cell packaging foam and a wire wrap on the valve open orifice. Why?
I notice, when I driven SMART on the dusty road I always have a same problem with valve - WOW! It is not surprise , if you start to think about. Rear wheels is a dust blowers in to engine compartment , so the valve has a direct access to that dust.
It is it for now. Will drive another couple hundred miles and give another report.
Happy Driving !
