To clarify my earlier statement about removing one of the two hoses that attach to the top of the TIK pipe, have a look at this picture:
The first hose from the left(vertical and the bigger of the two vertical hoses) is the hose you would want to remove from the TIK pipe. The TIK pipe is the black, horizontal pipe. Connect the removed hose to a catch tank (also called a CCV).
This is one our Canadian friends like. You could just remove and let it hang loose but that isn't a clean option.
You must also plug the TIK pipe's connector for the removed hose. Otherwise dirt and other things could get into the turbo and engine.
Now, why the heck should any 450 owner do this? There are 3 big problems with the design without a catch tank that can cause costly problems and negatively affect the life of your 450's engine.
The hose to remove is connected near the bottom of the engine block. This pipe is supposed to send any
hot oil vapor back into the engine via its
cold air intake (
problem #1: don't mix hot oil vapor with clean, cold air) to be re-burned by the engine.
Problem #2 is once the engine cools or is shut off that oil vapor then condenses (becomes a liquid again) and gets into the turbo and engine as liquid oil, which then could send it to the intercooler. NOT GOOD! We do not want this liquid in our turbo, engine and intercooler. There are many posts at
http://clubsmartcar.ca and the European Smart car forums detailing this as the cause of
problem #3: the intercooler fills up with this oil and then fails.
Aside from replacing the intercooler being a costly repair visit for our Canadian and European friends, here in the States it would be even more difficult and expensive. Good luck finding anyone that has the parts in the States. There might be one (G&K?), however ordering directly from Europe or Canada is your better option. It is an expensive part. Then look at the HOWTOs for accessing and removing the intercooler. Not fun for anyone which means doubly not fun for your wallet if you have a mechanic do it.
Look at that picture again. See all the grime and dirty, oily stuff all over the area where those two vertical hoses connect to the TIK pipe? That is caused by the oil vapor leaking out onto those surfaces and then cooling, which creates the thick, sludgy mess. This can also be the cause of a burning oil/rubber smell that the creator of this thread mentioned.
So yes, the best course of action is to avoid this problem all together. With such a simple and inexpensive fix (the catch tank linked to earlier in this post is selling for US$30 at the time of this writing), why wouldn't we?
NOTE: the above picture is from my silver 2005, fortwo passion coupe before I replaced the TIK Pipe with the 4-ply silicone TIK from
http://forgemotorsports.co.uk
